TwinTurbo.NET: Nissan 300ZX forum - disconnect batt . Jack up the frount pass side >>>
Subject disconnect batt . Jack up the frount pass side >>>
Posted by xteam300tt on March 26, 2011 at 11:55 AM
  This message has been viewed 323 times.
In Reply To how to remove & install starter motor????? posted by Redzunz on March 26, 2011 at 08:45 AM
Message put the ebrake on and block s behind the rear wheels . The starter bolts onto the front pass side of the tranny with 2 bolts . there is one nut holding the large Hot ( 12v ) wire on the silenoid take that off and there is one connection with a single signal wire , unplug it and the starter is free . note you may need to remove the heat shield covering the silenoid to get to the power wire connections . but disconnect the battery first of all . hope that helps .
